B Axis Unwind for post configurator
Hi all
For the NXCam users out there I have a solution for the B axis limit unwinding with automatic retract unwind then re-engage. It will insert the following G-Code at each axis limit and the retract re-engage can be customized to any value you like.
G91 Z2.0
M999 P0
G91 Z-2.0
G90
I have the required files for the V1, V2-10 and V2-50 and Solo if your lucky enough to have one.
Please send me a message of you need this capability and I will contact you and work through the install together. It only takes a minute or so.
