Can not get Stock lined up with Y axis
I’ve tried everything and can find no way of getting cylindrical stock to line up with my part on Y axis. I’ve done everything I can possibly think of. I managed a work around offsetting the A axis 90 degrees but this stops any further operations on a different axis.
Hi @Sharp,
I am not sure I understand your issue well enough to help out. Would you be able to explain further and share some pictures and/or your CAM file (if you are using Fusion 360)?
Hi Q,
it’s the issue you were trying to help me with via email. It seems impossible to machine round stock that is horizontal (A axis at 90 degrees).
