Error: Error: Tool orientation is not supported for available machine axes
I hve some problem with rotary function that my V2-10 is not supported
Error: Error: Tool orientation is not supported for available machine axes.
Machine angles not supported: A-154 B9.63e+03
Error in operation: ‘Rotary1’
Error at line: 1
The error “Machine angles not supported: A-154 B9.63e+03”, the “A axis” is being commanded to -154°. The Pocket NC “A axis” maximum travel is -25° to +135°.
Let me know what CAM package you are using.
pocketNC from fusion library
In Fusion 360, do not select a machine for the SETUP (see below).
When you post your code, avoid selecting “Use machine configuration”
See if that resolves your problem.
