If I am in a location that does not have internet service is there software that is downloadable to run the mill for extended periods of times?
Hi Gerald, When you connect to the machine via the IP address 192.168… that is connecting to the microcomputer on the machine itself and internet is not required. You should be all set. Internet is only required if you are connecting over the network via Ethernet instead of the USB connection or updating software. Thanks, Kerry
Ahhh, thank you. I didn’t realize that when I was looking at the website.
