Kinetic Software Updates
Currently we are at v5.4.7. Most is about “calibration” - I assume for the Solo.
I would be helpful to get some more informations.
Is it worth to update a V2-10? Besides some annoying anomalies when being used via SFTP and some weird behavior when NGC files have errors, the machine is working.
Most of the changes since v5.3.1 have to do with our new internal calibration process. Machines in the field already won’t benefit much from updating. We are planning a new release soon, though, that you may want to update to. Stay tuned!
Hi, I have a machine at v5.3.1
it is connected to internet but does not see any new versions, is that normal?
To connect to the internet the machine needs to be connected via an Ethernet cable. If it is connected to a network, you’ll see an IP address assigned to the eth0 device under Config tab > Server tab. If you are connected properly, you can click the Shutdown Services button, then click the Upgrade to v5.8.1 (currently the latest version). See this tutorial for more info: https://pentamachine.atlassian.net/wiki/spaces/KCUR/pages/1738571781/Kinetic+Control+Software+Update+Tutorial
error: Commit a5b6509bf77829164bc065a0715e5b1d54850eacca65992f8777e49ae8c55bc9: Signature made Thu Dec 5 21:59:37 2024 using RSA key ID 8FB9D19423755DA3 BAD signature from “Pocket NC Company info@pocketnc.com” Key expired Wed Sep 20 15:59:53 2023
There are instructions at the top of this page for how to fix that issue: https://pentamachine.atlassian.net/wiki/spaces/KCUR/pages/581074945/Kinetic+Control+Software+Versions
