Moisture in air for Solo
How critical is it to have dry air feeding the Solo? It’s going to be a while before I can get a dryer installed for my air compressor so all I will have now for moisture removal is a condensing filter. I’m in suburban Chicago, so it’s hot and humid this time of year.
That should be fine. Between your condensing filter and the one that is installed inside the machine, a lot (if not all) of the water should be caught.
However, if you start to see water coming out anywhere there is air coming out (spindle, air gun, etc.) then you will want to wait until you have a better way to dry to the air.
Thanks Q - Mike
