Hi. New CAM and V2-50 user here. I’ve been doing solid modeling for many years, but using Fusion and Kinetic Control are new for me. I’m sure I’m making a simple mistake. Hopefully someone can help me navigate through the issue.
I’ve had success with using Fusion to send gcode to my V2-50 and perform the goal machining with two simple parts. However, when i used what I am pretty sure are the exact same setup WCS, i’m getting mixed results with almost identical parts. I’m confident it is some small setting i’ve got wrong. But i’ve been troubleshooting for several hours trying different combinations of WCS in my Fusion setup as well as my tool orientations in my 2D boring operations without resolving the issue.
I keep getting gcode in Kinetic Control that yields error messages such as “Linear move on line 20 would exceed joint 0’s negative limit”. When i run simulator in Fusion the run looks perfect every time, but when i send the code to Kinetic Control the simulator shows that the model/stock is clearly in the negative (out of operating envelope) side of the X axis.
I’m pretty confused because this same setup (I think) has worked perfectly a couple of times with wonderful results in my aluminum part. I’m way excited about the V2-50 and Q at Penta has been super regarding helping. Great customer service.
I’m sure it’s likely something that i’m doing wrong in setting the origins in Fusion, but i’m not able to figure out what it is i’m doing wrong. I’ve seen from the forums that i can reset the G54 offsets by using “G10 L2 P1 X0 Y0 Z0”. I’ve tried that and started fresh numerous times without resolving the problem. My model/stock keeps pushing forward off of the build plate into the negative X direction.
Any ideas to help me head towards figuring this out? Thanks
