New User V2-50 questions - bought a lightly used PNC
After reading the manual
Q1: Spindle Air Pressures… Manual says - Min 20psi. What is the best range? What is the max - not to exceed?
Q2: Schunk Air Pressure… Manual say - min 72psi. What is the best range? What is the max - not to exceed?
Q3: System - since these devices air pressure requirements are different I assume I need 2 regulators.
Q4: Startup Tool Sets. I see that Penta used to sell startup tool sets from Daytron and Harvey. I would like to purchase these - if possible or get a recommended source and a BOM so I can get them directly.
Q5: Is there a plan to release an AutoProbe option for stock positioning? I see there was a Youtube of a users approach to this but would be very interested in a “factory” option.
Q6: Purchase of Schunk parts. I would like to get a couple of more locating pins. Are these and hold down pins available from you as a dealer or can you recommend a source?
Q7: B-table offset. I acquired the machine but would like to confirm the B-table offset. SN 3452.
Q8: Is there a Speed/Feeds/Material table set for the V2-50CHK? Is there a plan to publish this if not?
Thank you in advance…
HI all, I was able to get the answers to these and a few more questions from Matt at service@pentamachine.com … Thanks Matt.
