Not booting anymore
I have two machines working side by side. Suddenly one of them is not booting anymore. The beaglebone board by itself does boot but inserted it doesn’t. Is there anything I can try to fix this?
Thanking you in advance,
Jako
Ps: getting: error spawn EIO
@Jako it sounds like maybe there is some sort of fault on your machine’s main circuit board. To test this a bit further, please follow the steps in the attached document and then let us know what you find.
Your results will help us determine the next steps.
Power Supply:Main Board Testing.pdf (251.7 KB)
Thanks for the quick reply.
I have measured the two voltages but they are okay. What would be the next step?
Thanks, @Jako
At this point there are a couple of options but it may be better if we continue this conversation over email as I will likely need to get an address and other information from you.
Whenever it is convenient for you, reach out to service@pentamachine.com and we will continue from there.
