I would like to use M-codes and with that control an air-coolant and suction. Is there an output connector somewhere on the Pocket NC V2?
The Pocket NC V2 does not have any input or output connectors on it and the machine’s software is not set up for this kind of thing.
However, with some tinkering and some changes made to the software using the attached files, you can achieve what you are looking to do.
Please note that doing this will void the machine’s warranty and Penta Machine Company can offer very limited support on the process.
V2 GPIO Setup.pdf (783.1 KB)
v2_gpio.zip (1.4 KB)
Okay…well thank you. I will definitely take good look before doing that…but it sounds like a plan.
