Aluminium 6024
Depth of Cut: 0.7
Step-over: 2.4
RPM: 38000
Feed: 700mm/min
Chipload: ~0.022
Single Flute (Datron 3mm)
Adaptive Clearing was a bit noisy in some corners!
Cut off with 2D Contour Wrap and Ramp. Needs a steeper angle (deeper cut)
The Trick with Aluminium it seams, go faster go deeper.
The stats from G-Wizard were correct. I struggled because they seemed to extreme compared to HSMAdvisor.
