Hi guys.
I just installed a alcohol myster on my pocket NC and I was wondering if the pocket NC has ony control pins on it? I would like to trigger a solenoid valve to close the myster when the machnining job is done. So any kind of trigger signal would work.
Send an email to service@pentamachine.com along with your machine’s serial number. Also let us know which user interface you are using, our older Legacy software or the new Kinetic Control interface. The procedure for setting up an I/O pin for controlling external devices varies depending on the version of software installed on your machine.
