I’m using a Pocket NC V2-10 with Legacy control version 4.8.1 (not Kinetic Control).
Machining works correctly when the B-axis is at 0°. However, when the B-axis rotates 180° to machine the opposite side of the part, the second chamfer is not positioned correctly.
The issue occurs both in Fusion 360 simulation and during actual machining.
I have attached the part drawing for reference.
Could you please help me identify the cause and suggest a solution?
Thank you for your support.
forum.f3z (5.6 MB)
Hi @Onurkaskaya
I cannot see the file. Can you try sharing again.
I have added the drawings as of now. @TokyoPav
Looking at the data it seems the its out of position to the machine.
It appeared right at the center of the machine. However, that’s not my main issue; if you look at the toolpath, I want to machine the edge chamfer of the part—first one side, then rotate the B-axis to machine the other side. It handles the first side exactly as I want, but once the B-axis rotates, the tool ends up too far away from the part. What could be the cause of this problem?
Can you provide the new file with everything in the correct location so we can sort out with the exact same data you have. Not sure why it would be offset for me. It’s hard to work out what’s happening without the exact conditions you have.
I created a WCS on the stock to machine the part and saved it as G54.
I then set up the same operation in Fusion 360. I am using the RWO (Rotated Work Offset) method. My intention is to machine one side of the stock first, then rotate the B-axis by 180 degrees and machine the opposite side.
For the second operation, I want to use G59.2 as the work coordinate system.
However, after the machine rotates the B-axis by 180 degrees, it does not return to the correct position for the second operation. The coordinates seem to shift, and the machining position is offset.
Has anyone encountered this issue or can explain what I might be missing in the WCS, RWO, or G59.2 configuration?
From what I see is the PNC has the G54 set at the center of B axis rotation and that makes the part near the center of rotation and you can see the G code X values going from around 0 to 10 with the zig zag but when rotating to the other side its probably way off in position. In Fusion the part is much further away from X0 that what you see in the simulator. Im guessing something to do with your G54 position in Fusion. I’m not a Fusion360 guy so I’m not sure where you set that but will look and see if I can work it out. I just tried but I dont have a paid for license so I can’t test as i need the MFG-extensions that is a paid option. I think move the WCS origin to match the location on your pocket NC and try again or you need to set G54 on the pocket nc to match the Fusion360 position.
