PocketNC Enclosure LED Lighting
The enclosure for the PocketNC v2-10 is great, but it can reduce visibility and block some normal room lighting. To that extent, I wanted to add a good amount of bright white light with a low profile, low cost and custom fit to the standard enclosure size.
Bill Of Materials
- Print a total of 6 brackets and 6 back covers, contained in this Thingi.
- Count = #84 LED bulbs
- Count = #12 100 ohm resistors
- 8' 22 gauge wire
- Rocker Switch mount, separate Thingi
- Rocker Switch
- Power Supply
- Miscellaneous and Tools = Solder and iron, heat shrink, 3mm nuts/bolts
Links
Assembly
Each bracket contains (count = #14 LED bulbs, 2 series circuits) .
Circuit = #7 LED bulbs in series with a 100 ohm resistor, then each series in parallel with the Rocker Switch and Power Supply
