We want to switch from Fusion 360 to Siemens NX. Can anyone help me with adding a post processor and creating a post for V2-10? Our version is NX2312.
Hello @kerima7x
The posts and machine kits are available on post hub and self install when you select the download.
If you can’t access post hub there is a link in these forums for the download and instructions for install and how to modify the machine kit to make it perfectly accurate for you specific machine A to B axis offset.
Edit: here is the direct link to the kits for manual install.
https://drive.google.com/drive/folders/1S9dHMpPn8H5ZOpVdyJmf70ZyrLOTZL55?usp=sharing
Thank you[quote=“TokyoPav, post:2, topic:969, full:true”]
Hello @kerima7x
[/quote]
Thank you
