After upgrading my PocketNC today the normal screen shows for a second then the screen goes blank. See attached screen recording. Tested on macOS 14.3.1 Safari, Chrome and Win 11 Edge.
How can I revert to previous version or a solution tot the problem?
I wasn’t able to reproduce this issue. My best guess right now is a caching issue where it was trying to fetch old data. Holding shift and clicking refresh should force the browser to fetch the latest versions of the various files.
Upgraded to 5.5.11 and when connecting to the machine with a web browser the screen is correct for about a second then goes blank. I can refresh the page and the screen goes blank after a second again and can be repeated forever. My video posted in the first post is still valid to see the problem.
Tested on:
macOS 14.3.1 Safari, Chrome and Firefox
Windows 11 Edge and Chrome
Exactly the same behaviour on all 5 different web browsers used on 2 different operaring systems.
Shift click has no effect.
Version 5.5.9 works (Just need to figure out how toll do a roll back).
Can you tell me more about your specific machine configuration. Is it a V2-10 or a V2-50? Could you also open the JavaScript console and share a screenshot of any errors that appear there?
You’ll need to do this when updated to v5.5.11 for there to be any errors, but the JavaScript console is a window/panel in your browser. In chrome on macOS, you can press Option+Cmd+J to open it. I think it’s Control+Shift+J on Windows.
Installed 5.5.11. This time using Chrome on macOS to connect.
Attached is a screen dump of the JavaScript console after connecting to the machine. Screen goes blank after a second.
Ok, with your help I was able to reproduce and fix the issue. The fix is released in v5.5.12. For anyone who updated to v5.5.10 or v5.5.11, you can SSH to your machine and run the following commands to update (it’s also possible to get to the update section in the UI and if you’re able to click the Shutdown Services button before the white screen, then you should be able to update normally):
Thank you for the fast response solving my problem on a weekend.
I know of just a few companies having this great support (Great Coasters International , Hamrick software and Penta Machine!)
Thanks for taking the time to not only report the issue, but to intentionally go back into a non working state to help us diagnose the problem! You made many people’s update process go a whole lot smoother.
