I have a V2-10 with legacy software (not kinetic). It turns on, and boots into blinking red light. When I connect the USB, i get the beagle board black file browser, and if I use ethernet, it seems to not create the 192.168.7.2 or 192.168.6.2 website. I see the ethernet controller on the computer and it gives an IP address, but its different. 169.254.246.26 When i try to connect to this IP with the web browser, it doesn’t connect. Any advice would be helpful.
Did you install a RNDIS / Ethernet Gadget USB driver? This is needed. Also check the usb connector goes in far enough as mentioned in the other post. You should be able to SSH into the machine. You could also connect a hdmi screen via the mini hdmi connector to see what’s happening on the PNC.
It was the drivers for the usb cable. I didn’t try to get the Ethernet working. Once I installed the RDNS driver for windows 11 it works. Note to others, you’ll need to temp disable driver signing to install them.
