Fusion 360 “Center of Rotation” programming not working
I have an older PocketNC with legacy software and am trying to use Center of Rotation programming. Whenever I post, I still get M428 and M429 in the gcode. I saw on other posts which suggest unchecking a “Use TCPC” checkbox. However I don’t see such option in the lastest fusion 360 post processor. Any advice? Thanks.
The new post requires a machine configuration. You can edit the machine configuration and under kinematics select each of the rotary axes, where you can uncheck use TCP.
Great thank you, somehow I missed that I can edit the machine config. Works now.
