Joint 4 following errors after software update 5.8.1
Hi, after updating to 5.8.1 (or 5.8.2) (from 5.1.5) Im getting a lot of Joint 4 following errors on Fusion 360 rotary toolpaths. Im using latest Fusion 360 CAM postrprosessor with plugin. I have disabled G93 and G94 since those made more errors and my code looks like this
N74990 X-0.691 Y-1.757 Z2.234
N74995 G0 Z4.496
N75000 Z5.25
N75005 G53 G0 Z0.
(4_FLOW5 20)
N75010 G54 G0
N75015 G0 A0. B630.
N75020 M254 P9
N75025 G59.3 G0
N75030 G0 X-2.281 Y-7.214
N75035 Z5.25
N75040 G0 Z3.1
N75045 G1 Z-0.054 F1200.
N75050 X-2.242 Y-7.192 Z-0.135
It seems that on line N75015 every time I get error.
Previous 4th axis position is N61460 G0 A0. B720.
Please help urgently. Should i roll back to V5.1.5?
Machine is V2-50 CHK
What serial number is your machine? Could you attach your calibration data? You can access your calibration data by going to Config tab > Server tab > Machine Config panel. There’s a text box where you can enter a serial number and then click the Download button. Feel free to send this info to service@pentamachine.com if you would prefer not to post it here.
If the same G code program works on your previous version of Kinetic Control, I would revert and continue to use that until we can identify what is going on.
Hi, thanks for reply. Im getting error: uploading attachments is not allowed by new members. Also email rejected file attachment and getting google automatic attachment rejection messages from your server. Would you have some support system where I could upload the configs? EDIT: Sent a download link in email.
Sorry about that, I’ve made you a basic user so you should be able to upload files now. Otherwise, I can check with service later today to get those files from you.
I have your calibration files, and I’m not seeing anything out of the ordinary. Could you please include your G code program and any tool and work offsets that are in place on the machine?
Thanks, Work offsets used were Y44.0 Tools offset for 1mm ball end mill TLO -84,76mm. The problem occurs only on one combination with toolpaths connected (repositioned with Z Tool orientation rotations). Im out of workshop for few weeks and have to get back on the issue later regarding gcode.
Hi, I did more testing and it seems that old gcodes are not working (there is several issues related to toolpaths with B axis rotations with this update.
Could you help how to downgrade back to version 5.1.5? Can i use USB stick etc? I tested also the new versions after 5.8.1 → 5.8.2 and cannot do a reverse anymore from #/config/server (it shows only deploy 5.8.1 after I shutdown services)
I’m away from my computer right now, so I’m unable to get you back to v5.1.5 until Wednesday. These commands should get you back to v5.5.12 (see this page https://pentamachine.atlassian.net/wiki/spaces/KCUR/pages/581074945/Kinetic+Control+Software+Versions):
sudo systemctl stop PocketNC
sudo ostree pull kinetic 6e965ed2a4080300ed593eda7ec0993fd0fe55a7e12003278841aec0137bbce0
sudo ostree admin deploy --os=kinetic 6e965ed2a4080300ed593eda7ec0993fd0fe55a7e12003278841aec0137bbce0
sudo reboot​
In an effort to fix these issues, though, can you share your G code that isn’t working on the latest version?
