Hi all!
Recently, I’ve started working with some small diameter tooling (> 1mm) and I’m struggling to minimize the runout of the extended toolholder. Before I tighten the collet holder, with the collet firmly inserted, I’m seeing about ± 0.0002 of an inch of runout on the end of the tool. Once I tighten the collet holder firmly, I see all the way upwards of ± 0.00065 of an inch. This is with the supplied 1/8" collet–the effect can be even more pronounced between different 1/8" collets. Any thoughts on what may be causing the collet to shift off-axis as the holder is tightened? I’ve inspected the threads on both the extended tool holder and the collet holder, and both appear to be undamaged.
Stephen H
