Hi
When I set “Jog In Millimeters” for the pendant the minimum increment is 0.01mm when using the pendant. I think 0.001mm should be the minimum increment as with most other CNC machine HMI’s. This is from cold start before running a program that may switch the machine units. Just having the machine sett to MM in the Units settings.
I was able to fix it by modifying LINEAR_JOG_INCR_BASE in the INI OVERLAY to 0.003937.
