I am new to this forum and to use of the V2-10, but I’ve used Fusion 360 for years. I am having a terrible time configuring F360 to my machine. Putting to one side the clumsiness of F360, it seems that I need a .mach file for the V2-10, but what I get from F360’s library is a .f3d file; in any event, I get error message when I try to post to the effect that I haven’t configured the machine properly. What’s the fix? Where do I get a competent .mach file for the V2-10?
Upgrade to Autodesk Fusion (360 part of the name was removed years ago.
During CAM you need to post process your model, make sure you have chosen the correct post processor file for V2-10. Post the file and download that GCODE file to the V2-10 via it’s web interface.
Thanks. I’ve done that and now fixed the issue. However, now I get an error message whenever I try to run the G Code that the spindle movement exceeds permissible limits and params are wrong. The reason is that the G Code has movement values that obviously are too large for the Pocket N.C. (e.g., Z 2.028). I cannot figure out why this is happening; I’ve measured the TLO repeatedly, touched off the workpiece carefully, etc. I noticed that another user had a similar problem last October.
Can you share your Fusion file so we see what’s going on?
