I have an issue with Pocket Nc V2-10. Spindle stops turning during a fairly easy operation.I tried with tools of different thicknesses, but the problem was not solved. When performing the same cleaning operation with a different operation, the machine runs smoothly. Maybe you have an idea about it and you can give me some solutions. You can see the operation via atteched file.
I guess found the problem. There is a socket on the spindle pcb and one of the cable was break. We will try to fix and I will let you know the results. You can see the video of the problem and socket.
That could definitely cause the issue you are seeing!
It may be difficult to repair/replace that connector unless you have the tool for picoflex connectors. If you would like us to send you a short section of wires with that connector attached that you can splice onto the existing wires of your machine please email us at service@pentamachine.com. Please provide us with your machine’s serial number, a shipping address and a good contact phone number.
We don’t have the tool but we were able to crimp the cables to the connector and cable seems stiff and spindle works once we connect.
Apparently that fix didn’t make a difference to the spindle error as it stops working during the operation. I actually made successful operation for a while but later on I have changed the tool and start getting the spindle errors again. It actually occur more often in time and even I remove the tool and run the spindle empty it happened as well.
I have changed the spindle RPM and it didn’t make a difference. Now I am resting the machine and will make another run but what could be the issue here.
Thanks for the update. I am glad you were able to get that connector reattached.
It sounds like the ethernet cables running up to your Z axis and spindle (through the X cable chain) may be wearing out. We can provide you with new cables and instructions on how to replace them if you are able to reach out to service@pentamachine.com with the information requested above.
