Hello, I have some problems with the Post Process in Fusion: I’ll get the following warning:
“The hardcoded machine configuration is overwritten by the provided CAM machine configuration.”
The properties ‘Use TCPC mode’, ‘Machine model’ and ‘Use inverse time feedrates’ are ignored."
I need TCPC mode for my 5 axis part but I don’t have so much experience with the machine and fusion and can’t find the reason for this Problem. I hope anybody could help me with this issue.
I believe the machine configuration chosen in your CAM setup is not aligning with the settings selected in the post configuration window that comes up right before generating g-code.
For now, I would suggest not using a machine configuration in your Setup as it is likely outdated. A new version may be released in the future, but when that will happen is unknown.
