Y axis getting stuck not moving when probing the tool length
Hi everyone,
had a recent issue with the pocket NC. It has happened twice. The first time I restarted the program and it went immediately away the second time it took several tries to get it to work properly again. The issue is that when the program starts it goes to measure the tool. When the Y axis is moving to go negative to align the tool with the measurement probe the y axis stops moving and it starts to sound like the motor is stuck but sounds like its rotating internally. The coordinate in the y axis display keeps moving as if the axis is moving but it’s stuck. I have to stop the program so that the tool or the spindle does not crash. I was wondering if this is an issue with the Y axis stepper or maybe with the screw slipping from the motor drive. If you could let me know how to troubleshoot this issue.
Regards,
Hi Jose,
It sounds like there is too much resistance on your Y axis so the stepper motor is slipping. We got your email as well so my colleague, Chuck, will be getting back to you with some next steps.
QR
having the same issue, any advise on this ? was running the machine most of today and it was running fine, changed the program to a different part and the y axis movement is super clunky, so i stopped the program and cleaned the machine a bit and now when it goes to probe the tool length the y axis gets stuck with the tool an inch and a half or so above the table and then starts the tool probing cycle.
Hi Q - I’m having the same issue as Jose with the Y axis binding. Can you please send the next steps to me, as well?
@jennchm Sorry to hear that you are having some trouble with your Y axis binding. I would be happy to help you with troubleshooting the issue.
To properly track this issue and the troubleshooting done to resolve it, could you please send us an email at service@pentamachine.com stating the issue and the serial number of your machine? From there we can send over next steps and specific resources for your machine.
Same issue here. The machine can run in manual mode and homes fine. But when I tried to measure the tool the Y axis got stuck with the number on Y location kept going. Then the spindle try to crush the tool into the stock.
Any advice?
Thanks
Same issue, does anyone have the solution for this error. please share.
a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; }
It appears that the issue was caused by debris. The machine was properly cleaned and lubricated, and the problem was resolved. The machine operates correctly during manual jogging. I suspect this may be due to a low voltage input during the probing cycle.
It seems regular cleaning and lubrication mitigates most issues. Looking at similarities over the years usually a good clean sorts most of these issues. This is a good reminder to do some deep cleaning
